  • Replies 44
Trick piece of kit! Looks awfully useful.....
Does it move much?
Where abouts is it based and what kind of rent is it?
We used Sean a few weeks ago on a HC Dismantle, such a great machine. A lot less sway and movement in the basket compared to some tracked machines. It did the whole tree from one spot, no need for shuffling around. Worth every penny!
Sent from my SM-N9005 using Arbtalk mobile app
Platform is 28m with working height of 30m,
has an 15m outreach at base then starts arching back once at 10 m high
machine legs are only aswide as machine, machine is 2.5 m wide
so if you can get machine in you don't need any further room to set legs up
