560xp Oiling Problem?
Tommy O
have got a slight problem with the oiling on my 560xp. no oil is feeding out on the bar and chain instead when it is running it is coming out from under the muffler? i have check the oil pump pipes seem to be free. could it be the gasket on the crankcase? obviously don't want to run it with the muffler off to check that. has anybody else has this problem or know what it could be ? cheers Tom
there is a recall for this fault on some saws, take to your dealer to see if yours is in the serial number bracket for a free fix:thumbup1:
Not a recall, but a service bulletin.
It is worth checking out if it is an early saw. Start with checking for loose case bolts.
I had this problem with the first three 560s I had. It was a problem with the gasket between
the crankcase. They all eventually pissed oil out. Got them all fixed under warranty, and now
the newer ones have had the problem sorted so my dealer says.
