Hi everyone, the bearing has gone on the top roller on my greenmech 15.23. It's become lopsided but the rollers still working fine. Does anybody know roughly the cost of the parts needed and whether it's a fairly straight forward job?
Thanks Jordan
If you are mechanically minded then it isn't a big job, but I wouldn't continue to use it until fixed as you may damage the roller, bearing housing/yoke and motor (possibly all 3). Is it definitely the bearing and not the yoke pivot?
  Rich2484 said:
If you are confident in doing it and can get the sizes or numbers off the bearings try these people. They are fast at postage.
Green mech bearings where £90, £12 on this site. Used there bearings for a long time now and not had any problems.
Simply Bearings Ltd ~ Oil Seals SKF FAG TIMKEN KOYO NTN NKE TRULOC Needle Rollers Taper Rollers Rod Ends Oil Filled Bushes Loose Balls O Rings Grease Plain Thrust
Mmmm, that looks an interesting site Rich:001_rolleyes::lol:
I wonder where that one came from:001_tt2:
Yeah yeah yeah. You put me onto them. Ok. :001_tt2::001_tongue:
Read more
