Hi all,
I'm in the market for a new big saw, I have had a Dolmar Ps6400 for nearly 12 years now and its still a cracker but only runs a 24" bar and it struggles in some rough stuff. I've been looking at a Stihl 660 with a 30" or 36", does anyone know if there is a Dolmar of equivalent size?
If there is, where would I get my hands on one, hopefully in the UK?
  • Replies 49
Hi all,
TDC may be able to help . He imports them ...
it will be difficult or nigh on impossible to get a new big dolmar in the uk TCD imported my PS7910 from THE USA i bought my ps 9010 from germany
Hi thanks, but who or what is TDC?
Sorry . Timber cutter Dartmoor . Affection ally referred to as TDC :biggrin: He is a member on here .....
I t will be difficult or nigh on impossible to get a new big dolmar in the uk TCD imported my PS7910 from THE USA i bought my ps 9010 from germany
What are your thoughts on the PS 9010 compared to more main stream saws? How long ago did you buy it and what sort of money would you guess at the moment I should expect to shell out?
The dolmar / makita 6400 7300 and 7900 all share the same chassis so you should be able to put a makita / dolmar 7900 pot and piston on your 6400....
Or you can get this which will give you 84cc :thumbup1:
Nwp Big Bore Piston & Cylinder Assembly (54Mm) For Dolmar 7900, Makita 6401, Solo 681 Chainsaws | NWP | Pistons, Cylinder & Ring Kits | www.baileysonline.com
Thanks, i'll look into them.
