Chipper bearing failed yesterday
I new the fins where bad when I brought the machine
So brought belts fins bearing etc to rebuild it
The Q I want to no is would u use some sort of thread seal on the 6bolts that hold the fins
Reason why I ask 4 of the 6 bolts rung of and I think they used thead lock or loctite
And any over pointer to the rebuild would be great
Cheers martin
  • Replies 29
Yea they want loctite thread lock on them but before you lock em in I'm sure the flywheel will need balancing with thin washers on these bolts, I was told by an entec dealer years back that if the flywheel is balanced perfectly you could stand a 50p on its end on top of the machine while it's running flat out, never tried it though :)
Im sure you dont loctite the fan bolts I believe you only lightly oil them, it has been sometime since I done the training course with Timberwolf, I would definately give Timberwolf a call, speak to Barry or Clive.
Kev are Orange plant going to continue being timberwolf dealers and stockists or have they ditched the wolf? And just doing greenmech from now?
Sent from my GT-I9300 using Arbtalk mobile app
When we did ours we balanced the flywheel by adding washers to the bolts that hold the fins on. Make sure the flywheel is scrupulously clean before you fit the fins as little lumps of crud can crack the fins as you torque them up.
Scott the only difference within Orange Plant is the selling of New Machinery, We will still sell used Timberwolfs and all the servicing and parts will remain the same.
Hope this clears things up for you mate.
