And LAN88 how would I adjust these settings? Had a look before and couldn't see a way to adjust the bridge, cheers
Sent using Arbtalk Mobile App
There is a torc screw in the rings that you can undo, there are 3 potions that you adjust the rings through. use lock tight on the screw when you put it back in. I still had to get a shorter bridge as well.
The bridge is available in 25, 30 and 35cm lengths while stocks last.
The new bridge on the new sequoia is a rope bridge, available in the same lengths but you would need to change the leg loop/bridge rings as the rope bridge wont fit through the gap.
No more sequoias available until the new version arrives.
