I'm sure this has been asked about before but can't seem to find anything and models are always changing anyway so here goes.......
The lad that helps me out wants a saw to start with and enable him to do his basic tickets, so what is a good first saw that will eventually fit into a multi- saw set up?
Years ago I started with a Sachs-Dolmar (50ish cc machine if I remember correctly) with an 18" bar. Used for a bit then later complemented with a smaller husky and an 066. They got nicked but were eventually replaced with similar (346xp ( which he isn't going near....it's my baby), 365 & MS660).
Reading another thread it suggested than a 346xp would run an 18" bar if needed (?) so would something like that with a 13" & 18" bar make a good first saw?
Any suggestions gratefully received.
If you can get a 346 then yes . Best with a 15" bar balance wise but would pull an 18" on the odd occasion . However as has been suggested 550 or 560 ........
346XPG - if he can get one
545 - though reckon it'd struggle on 18"
MS 260 - not 261
550XPG - if he can afford one
Equivalent Echo to MS 260
MS 241 C-M
Agree. Bear in mind that the NPTC courses want a maximum of a 15" bar.
What he does next with the saw determines whether to go for a 346/550 or jump to a 560.
Tree surgery I reckon the 560 would be the mutts for end of day general ringing up, with a 15 or 18 fitted. But if it's woodland work and he's going to spend the whole day swinging a saw, then the 346/550 is a more comfortable saw weight-wise, with a 13/15 bar. Being a bit lighter does make a difference. And they will pull an 18" bar
He's not the biggest lad which makes me think the 346/550 route would be best to start. As no doubt I'll be buying it ( to be paid back tho!) he needs a top quality saw IF it will fit into a multi saw set up, which the ones mentioned will, and I don't mind him using my 365 should needs arise.
Cheers chaps....but keep em coming.
346, 353, 550, 545, if your lad can manage it, 357, 359, 560 or 555. IME stihl is overweight and nobody cuts on the torque band
Sent using Arbtalk Mobile App
