The bar will fit, no problem - but run it with an 8-pin if it is 3/8".
If it is a .325 bar, run it with a 9-pin (a smaller one won't fit on the 461 clutch drum).
The dl count of the chain may turn out to be an issue, you likely will need an extra dl with .325x9.
Different sizes .325 on 261 and 3/8 on 441. Why not just go for 660?
Sent using Arbtalk Mobile App
It isn't that unusual to run 3/8" on 50cc saws, so you don't really know that. See my post above though....
