Which chain oil are you chaps using?
jnoon
Hi all
Quick survey?!
I've been on veg oil probably the last18 months , like the idea it's environmentally friendly & not harmful to breathe in.
Just wondering what other chaps are using ??
The cheapest I can find "proper bio chain oil" is Clarkes super tack bio @ £55 25l
My veg oil is around £25 for £25l
Using a can a day (approx) some times less some times more it works out including mix £208 a month for veg oil& mix
Or £280 for super tack &mix
(Based on stihl hp super oil & current rate of petrol @ £1.36l)
Question is do I carry on with the veg oil all be it a bit dry in the longest bars & the £72 a months adds up and I would have thought should easily cover any extra wear In bar & chains
Hope to get a few replies
Cheers
Some of this bio oil dries like syrup on to the saw and is nigh on impossible to clean off - have some thought for the saw techs - some take hours to clean:001_rolleyes::thumbdown:
Not to mention the damage that can occur to those saws that are not serviced. I often see the cooling fins totally blocked with the glue from bio oil.
Cooling fins are there to cool, blocked ones not only prevent airflow, but effectively insulate the ally resulting in very poor heat conductivity from the cylinder to the air.
The result? Possible seizure, or baked crank seals, followed by lean seize.
It does happen.
