No unless you want a hernia...
Tirfor tu16 is a good blend between power and weight. Good for assisted fells and hung up trees..
Tu16 can be bought on eBay for under £250
I bought this one for about £235 as I had a long term borrow of one.... I also bought a little lug all for smaller stuff.ImageUploadedByArbtalk1392663948.003804.jpg.2baab0451e3fe32e4c17e7c5e5eda81e.jpg
Hope that helps, I bought a 5t ace when I started but quickly sold it on for £100!
  • Replies 21
Used to use a Tirfor t35 - bomb proof but weighs a ton. No good if you're working a distance from the van.
Bought a 1600kg Jet hoist winch last year - less than half the weight and will lift the same with a snatch block - not that I ever need that much umph! (I've pulled the van out of a couple of ditches with it!)
I heard that the Tirfor patent expired and now it's non-slip design has been copied successfully by Ace, Jet etc.
I'm not sure if the "get what you pay for" addage stands any longer on this one.
