has anybody had problems with the injector chuffing or black death at all
Yep. Currently off the road through the injector chuffing.
Then it snapped while being removed. Not much fun and no van for a week or two so far.
  • Replies 22
i got the same problem with my jeep grand cherokee back two injectors are chuffing and wiring loom for the injectors has gone brittle with carbon :thumbdown::thumbdown:
I had the injector seal leak on my Vito 110CDI was an easy fix just loosened off the clamp that held it in and went for a drive (as they're always stuck in there) and the compression popped it out in about 2 miles.then got someone to fit anew seal washer and re tap the thread for the clamp bolt,jobs a good un. If I remember correctly most of the pullers destroy the injector in the process of removing them so driving them out can be best, yet never recommended by mechanics
WM Tree Services
http://www.bestkenttreesurgeons.co.uk
