Reversed over my oil can miles from nearest chainsaw specialist. Managed to find a local garage/supermarket.
What grade motor oil would you buy to put in to finish the day without harming the saw? There was sunflower oil on the shelf as well.
Sunflower/veg oil is fine
Second that although rapeseed is the best of the veg oils - usually sold as "vegetable oil" funnily enough.
From a garage just selling mineral lube oils, the thickest you can get I'd say; it thins down in the hot crankcase tank anyway and will resist fling better than thinner oils; so that's 15W50 rather than 0W30.
Veg oils/old filtered chip pan oils can stiffen up the chain when it warms then cools also as it oxidises. Fine when it gets going tho I know a few lads that warm the bar/chain with blow torch before firing up the saw
