  • Replies 118
I use the softer mesh for the pines and similar. I wouldn't use tall guards at all as they will die.
codlasher
Good to know. I'll look into replacing them.
Out of interest, when you buy "one" Tubex tree guard (for about £1.20), do you get a single tube or a nest of 5?
Did the number of stakes & tubes match? Seem to have more tubes left over than stakes at the moment. Fortunately, I have some of my own spare spirals as ran out with shrubs to spare
Ha, no none of the numbers matched, loads of plants and not enough tubes or guards, I think some of the plants were sort of add ons- ie just little suckers that were a bit small but they put them in the bag anyway. The worst to plant were the oaks because there roots were so deep- ended up digging 1foot pits for the oaks whereas the cherries/birch and hawthorn hardly needed much more than a 1 inch diameter hole!
I think £1.20 would be for just one guard- I notice the price drops considerably the more you buy.
Just looked on the Tubex site and you're right, they are that much each.
I'm not going to uproot them all now! They're at 2m spacing and I'm hoping it will encourage them to grow straight. A lot of the other bits are spaced more but we were running out of space.
Ha! Don't worry, I wasn't suggesting you pulled them out! It was just a thought that happened to occur. Probably not a good idea (for the various reasons mentioned) as the vast majority of tree planting seems to be dense and thinned rather than thin and fill gaps later.
At least the end is in sight now. I get quite a lot of pleasure from seeing chillis on chilli plants and even little rocket seeds germinating, so I can only assume you'll get immense pleasure from seeing the trees grow and become a woodland... :thumbup1:
