  nick channer said:
Do you do a load handler that would fit say a 14ft ifor Williams flat.
ifor do a 12ft tipper with sides and mesh that you could section as well. I know you like to deliver lots in one go.
  • Replies 33
Nick, thanks
Tricky.... we've had brackets designed for Ifor Williams trailers by another arbtalk member but have been so busy we haven't manufactured any yet :blush:
We get alot of enquiries for trailers and I can see the benefits. The engineering work is beginning to get a little quiet - we're between projects - so maybe we need to make some.
  LoadhandlerUK said:
Nick, thanks
Hi does a load handler work if you've a canopy on the back of the truck?
( sorry to hijack original post!)
My dad works a 16ft flat bed trailer with his Toyota Surf.
Trailer fitted with a hand powered crane/winch at the back for lifting off large 1m3 bags.
Allows him to do a few deliveries in one run.
Probably get 5 or 6 cube on in one go.
by loadhandler - are you refering to the windy wheel on a carpet type affair - seems slow but less backbreaking than individually hurling them off.
Read more
