Best kit for starting out milling?
DJP Arb
Hi everyone.
Just after some advice on a starter set up to do some milling. A friend of mine owns a farm and quite often has some vary mature oaks come over in the wind and up until now I have just been logging it all up for the farm cottages.
So here's the question.
What's the best saw and bar length? Also what milling equipment do I need to get stared? I'm looking at a portable system! I was looking on Frjones but ended up confusing myself.
Cheers
Guys
  • Replies 33
I use a 660 and have 20, 30 and 36 inch bars and milling chains which I use on a 36 inch Alaskan. I chose a 660 because I also use it for other cross cutting and felling and its far more useful than an 880 would be - but that's just my opinion. You can cut wider logs with this set up you just need a mini mill as well so you can quarter-saw the log
Not sure on timber size guess it depends what's available to cut?
Have been looking at the following. Will this be a good start?
Alaskan Mill Mini Mill | F R Jones and Son
Alaskan Mill Mk III + 36" handle and rail set | F R Jones and Son
Alaskan Mill 9ft EZ first cut rail system | F R Jones and Son
And using a ms660
Rob D on alaskan mills is a good place to both buy and get info.
Buy a big old chain saw and get a 36 inch bar for it. Then a granberg milling chain off rob and an Alaskan III 36 inch (better value than 30inch). Then a cheap aluminium ladder off google and drill holes in each rung to get a straight start. Voila!
Cheers dude
