stihl 084
colwoodlandcare
  • Replies 21
Not too sure, haven't received the saw yet, have just purchased it. It still all runs and cuts.
When he took the E-clip off the chain break system the clutch fell out without him having to unscrew it a lot of melted plastic inside.
So something seized and melted.
bearing or maybe the clutch got overheated ???job to say without looking at the saw.
Could be the pictures but looks like a complete needle bearing failure.
The crank seals are replaceable, quite straight forward. Looks like needle bearing failure has also caused the clutch to undo and rattle around.
Clean it up, re assemble and check it's all working, do it in stages checking each part carefully on re build.
