im toying with the idea of getting a 130 or 110 tipper as this would do away with the pick up and hi lux and save me running two vehicles, i can also then tow 3.5 ton and remove more timber off the job (legally).
What size are the chip boxes, I've seen a few that look a reasonable size but how much chip will they carry. cheers
I have a 110 V8 ...
I would be carefull about towing 3.5 tonne
Hills would be an issue , so ask in a landrover forum ...
Air brakes are mentioned when discussing towing ...
Though many posts suggest landrover is better for real towing .. As opposed to hilux etc...
I owned a hilux & it was fun ... Though landrover heavier & more secure footing whilst towing...
Hope this helps....
It would depend on your trailer & brakes & four wheeled trailer deffo better....
cheers Dan, i know chip varies in weight what size dimension is your chip box? any bigger jobs the mog goes on site it would only be for smallish domestic jobs.
130 are generally 3500kg but check the plate as there are some at 3050kg, 110 are generally 3050kg unless you find a heavy duty one or uprate it to 3500kg, personally I would go for a 130 as the extra wheelbase length and capacity means a decent size with little overhang, but they are harder to find decent second hand ones.
I have a 110 V8 ...
Hope this helps....
Really ?
I have an ifor tri axle and it virtually puts me through the screen when I pull up sharp especially when loaded, and my twin axle isn't exactly shabby at stopping.
The only time my backside grabs the seat is if it's icy :)
A decently setup trailer will not need air brakes.
How much are you gonna spend Rab?
Capacity wise a 110 will be tiny, a 130 might be the same as your renault, but a different shape. Having coils on the back makes them tow so much better than all the leaf sprung pickups.
110 all the way as this vehicle has the weight more centralised over the axles . 130 full of chip is like steering a boat in choppy waters . Chip wise not an amazing difference . I've run both and now just run the 110 tipper .
That would not be too bad I suppose I think my renault holds about 6 cube do you think a 130 back would hold that? Budget wise I'm not sure yet as I would have 4 vehicles to sell first before I buy one. :001_rolleyes:
Whats the dimensions of your chip box Paul, you have run your 110 for a while now do you find it's too small ? They say size is important or is it how you use it :001_smile:
I have run my 110 tipper for almost 10 years or possibly longer . It has been my main vehicle for the last 5 years . I also run an l200 crew cab which pulls the trailer for timber removal . Chip box size on my 110 is 7ft long by 69 inches wide and 4ft 4" in height . I also have a high tailgate which helps me fill her up . Oh and a sign written heavy duty tarp which cover's the top and sides . I have numerous tip sites in my area of operation which does help . I quite often think of going down the transit route again but I then remember the rust and lack of 4wd .To be perfectly honest my landy is cold in winter and cool in summer . Just ticks all my boxes . I am considering converting the l200 to a tipper only for log deliveries . Hope this helps .
Can dig some random pics out if you wish ? Will be tomorrow though ; )
Edited by White Noise
