what petrol pressure washer?
simonm
Im looking at buying a petrol pressure washer to run off of ibc tanks full of water to keep my vehicles nice and clean. can you recommend me 1?
i run a cold presure washer off a ibc tank i got a fitting to screw into tank and a fitting which clips on and pipe fits to presure washer. filled up its heavy i have a 700ltr and thats 700kg of water my nissan knows its on back plus if half empty it will go back and forwards like being on a ship.
yhe preusure washer i have has a honda engine with a interpump fitted best pumps you can get italian and my goes at 1600psi. the cheapest way is if you can get a 5hp engine then get a 1600 or 200opsi interpump and bolt to engine and make a frame for it to go on the good washers new to that spec are £1000 but as other posts if its to keep trucks clean then get a steam cleaner with detergent unit will clean them like new. i do not know if they will run on gravty feed oronly main presure. karcher do a good hot one or genie but again interpump for the pump
