Try Mansell Griffiths or JL Harris both good old Solo dealers in Wales they might e able to help you, i contacted one of my old Solo colleagues who has pot/piston and other bits for a Rex but alas no bar, you can say Les from Oregon sent you via Barry Reekie, we are both ex Solo and Barry worked for Minok in Tovil back in the day
  • Replies 55
thanks les i will stihl sorry habbit lol still live in hope then and look them up meantime i,ve had t rex running tonight she,s sweet ticks over nice now starts well done points n stripped carb/fuel lines out etc all gunked up and points needed a clean no spark alls well now though t rex is apart from the paint scuffs bang on runs like a old cz bike ring ding ding ding etc
hers some more pics with some measurments etc
solorex2036_zps8533967a.jpg solorex2038_zps669dc167.jpg solorex2039_zps7e6edac6.jpg solorex2049_zpscc3d58ac.jpg solorex2051_zps095941b0.jpg solorex2052_zpsc9799d9a.jpg solorex2042_zps2549d528.jpg solorex2040_zps8ba1b224.jpg solorex2048_zps462e004e.jpg
Looks like it needs the big D009 type mount for the studs, what's the diameter of the clutch drum and crankshaft pto side where it enters the bearing for the sprocket
Sent using Arbtalk Mobile App
i will strip the sprocket off in the morning and get the sizes inc pics etc
PS i maybe able to remove chase the old sprocket of the drum in my friends lathe and retro fit a more common size sprocket back into place not sure if its been done though before but i can true everything up in the lathe tack weld it up to keep it true then fully weld up from the inside providing i can get a sprocket with the right ID for the bearing just an idea floating round in my head atm
If you're going to do that, why not go with a rim sprocket set-up?
D009 is the standard bar mount for the big Husqvarnas. If you can find someone nearby with a 3120, 395, 390 etc you should be able to check which bits fit. I suspect some holes may be needed, but it could be as simple as widening out the tensioning stud hole and drilling a new oil hole.
Hard to tell on the clutch drum but 94mm OD is big. I've had a quick look and the 090 is 100mm, the 070 is 80mm. 3120 is around 87mm. Once you've got yours off it's worth re-measuring to see if the Husky one is actually a fit.
Alec
Edited by agg221
on the earlier rex the clutch is on a splined cramkshaft model no 600010
on the later rex the clutch is on a left hand thread model 60104
this is what it is on our two saws and also some models have automatic and hand oiler there are three ways to check this an adjuster screw by the petrol cap and air line from half way up the cylinder block running to the oil tank or after you have used the saw if you unscrew the oil cap you should get a rush of air come out
Edited by shavey
