Hi I have bought a big stihl saw I was told it was a 075
But I am not sure as there is no name tag on it
The trouble is it looks the same as a 051
It has no manual oiler or decompression button
I have listed it on eBay for sale and don't want anyone buying it by mistake
Is there any way of finding out what it is
I know it's a 1978. Model
Any help would be great
cylinder head on the 075/076 has 6mm studs that run all the way up to the top ie about 5" long and visible
The 051 has short 5mm bolts which only the heads are visible at the base of the cylinder.
Also the 075/076 normally have the manual oil pumper in front the handle whereas the 051 wont. They are the obvious differences.
The fuel tank on the 075/076 is slightly wider but unless you have another saw to compare it to its not to obvious as its only a few mm wider.
Get a pic up! :sneaky2: Or if your near Exeter I can have a look and soon tell you.
Edited by wisecobandit
Easiest way to check is look in the holes by the plug, if it's got a big screw in the top hole it's an 051, if it's in the right hole, it's an 075
Sent using Arbtalk Mobile App
Easiest way to check is look in the holes by the SPARK plug, if it's got a big screw in the top hole it's an 051, if it's in the right hole, it's an 075
Ie for the compression release valve :sneaky2:
