I don't know if this has been up before? It got me scratching my head I can tell you?:biggrin:
Eddie.
[ame=http://www.youtube.com/watch?v=7dZ5BV0TvGQ]Russian Log Truck Loading - YouTube[/ame]
Better to put choker chains around the log over the head boardand onto the chassis lift the body which will drag the logs in and close the tail gate u could do large bundles at a time then
Same principle as winching a tractor backwards out of a bog with a sturdy rope tied to the rear tyre/tyres.
Engage super low forward gear and try and ensure the rope feeds in between the centre-line of the tyre cleats.
Since traction between the ground and the tyre is almost zero this will work.
It winchs the tractor out backwards, winching in over the top of the tyre.
I have used it successfully.
Probably simpler to use another vehicle, but bytimes there is not one available.
m
