  • Replies 70
A few more pointers on red diesel from farmers weekly
The line between doing the right and wrong thing with red diesel is blurry to say the least. To help get to grips with the subject we put a series of questions from Farmers Weekly readers to HMRC.
Red diesel rule-breakers generally fit into two camps - those that think nothing of topping up the pickup with red for the family jaunt to Brittany and those that don’t even realise they’re doing it.
For the former, the finer points of the red diesel rulebook probably aren’t worth worrying about. But for those that intend to play by the rules there are plenty of grey areas that can get you in a fix.
As with most legislation, it’s rarely perfect when applied to real-world situations, so a degree of common sense is required when interpreting the answers - on both sides.
If you’re still in doubt after reading this it’s probably worth checking with HMRC.
Q. What vehicles can I run on red diesel?
A. Red diesel can only be used on the road by ‘exempted’ vehicles. To qualify these vehicles must be engaged in an agricultural, horticultural of forestry related activity. These vehicles include:
Tractors - as well as agricultural, horticultural or forestry purposes, tractors can be used for cutting verges, hedges or trees bordering public roads. Since November 2013 gritting of roads, including travel to or from where gritting takes place is also permitted.
Light agricultural vehicles – this refers to any single seater machine that weighs no more than 1000kgs. An ATV is the most common example (and farm buggies?).
Materials handlers such as telehandlers and loading shovels.
Agricultural engines - this refers to any self-propelled agricultural machine. Combines, forage harvesters, pea viners and sprayers all come under this category.
Snow clearing vehicles and gritters.
Mobile cranes and diggers when in use or travelling to and from the place of use, providing they do not carry any unnecessary load.
Q. Is there a limit on how far I can drive with an agricultural vehicle?
A. You can travel as far as you like on red diesel providing you are performing a task, which is solely agricultural.
Q. I am an agricultural contractor. Are there any restrictions on when I can use red diesel?
A. To be able to use red diesel the nature of the work must be agricultural, horticultural or forestry related and the contractor must be acting in the same capacity as the farmer would. The vehicle must be registered as being in agricultural use.
Q. What are the penalties for using the wrong diesel?
A. If you are detected, HMRC has several ways of punishing you. It starts by charging a restoration amount for removing all traces of red diesel.
This includes a fee for removing and storing the fuel. On top of this there’s a fine to the value of lost tax revenue based on the size of the vehicle’s fuel tank.
The maximum fine for all of the above is capped at the value of the vehicle. In some cases HMRC will go further and issue a fine for lost revenue (the difference between the red and white diesel duty rates) for the entire period of misuse. This could be the entire duration of ownership.
Q. What is the tax rate for red diesel compared with white diesel?
A. Red diesel is taxed at 11.14p/litre, white diesel at 57.95p/litre, and Ultra Low Sulphur diesel at 57.95p/litre.
Q. Can I swap between red and white diesel by using two separate tanks?
A. No. Carrying two diesel tanks, which are both capable of connecting to the engine is illegal.
Q. What are the rules for storing red and white diesel on farm?
A. Each product requires a separate storage tank and hose/gun outlet. Each tank should be clearly marked, with the one containing red diesel showing a statement to the effect: “Not to be used as road fuel”.
Q. Can I use red diesel in my farm 4x4 if it is used only for agricultural purposes?
A. If it isn’t taxed and never goes on the road there is no problem fuelling a farm 4x4 with red diesel.
If the vehicle is only going to travel short distances on the road between different blocks of farmland it is possible to apply for a NIL licence from DVLA. This limits the vehicle to journeys of just 1.5km, but means it can be run on red diesel.
Q. I sometimes drive a vintage tractor out on a road run, about 10 miles or so, with a group of like-minded friends. Can we run on red diesel?
A. No. This is not agricultural activity. White must be used.
Q. A contractor travels to a farm to make silage, which he then hauls to the owner's yard. Is this agricultural or is it classed as carrying goods for hire or reward?
A. If the contractor is cutting and collecting the silage as well as transporting it, it is an agricultural activity, which qualifies for red diesel use. Merely moving the silage after someone else has cut it constitutes haulage, for which white must be used.
Q. Is there a limit on how far I can travel as a non-agricultural contractor?
A. If you are registered and using white diesel there is no distance restriction.
Q. What are the requirements for vehicles registered for non-agricultural use?
A. Any vehicle carrying out non-agricultural operations must be taxed, run on white diesel, and may need to have a tachograph installed. The driver may require an HGV licence, trailers must be plated and tested by the DVSA and the owner must hold an operator’s licence.
Q. When would I need an Operator’s Licence?
A. An Operator’s Licence is required for carrying goods in vehicles used for hire or reward.
Q. Can I tow a digger on a low-loader to use on another farm?
A. No – this is classified as haulage. But if the tractor is to be used for agricultural work on the farm or is needed to tow another vehicle back from an agricultural activity it has been involved in, then it can be run on red diesel.
Q. Can I take scrap metal from my farm to the dump?
A. As long as it is scrap of an agricultural nature, for example disposing of an old barn or milking parlour to clear the site for another agricultural purpose, then red diesel can be used.
Q. Can I use my low loader to transport farm machinery from one farm to another?
A. No. This is classified as non-agricultural haulage, and the vehicle must comply with non-agricultural regulations.
Q. Can I haul grain from my arable farm to my livestock enterprise; or to the local mill; or to my neighbour’s farm?
A. Yes, to the livestock enterprise and the mill. Haulage to your neighbour’s farm depends on the reason. If you have hired storage from your neighbour or are selling to them that is fine. But if you are moving it as a favour to your neighbour who the crop belongs to, you must not use red diesel.
Q. Can I supply red diesel to other farmers?
A. Anyone supplying or dealing in red diesel and paraffin must be approved by HM Revenue & Customs (formerly Customs & Excise).
However, this does not apply to those who obtain these oils for their own use. For example, if a farmer buys red diesel or paraffin for his own farming activities but occasionally hires or lends machinery to other farmers, with an operator, then they do not need to be approved.
However, if the loan/hire is so frequent as to constitute a machinery hire business, the farmer must be approved under the Registered Dealers in Controlled Oils Scheme. Buying groups which act as agents in the transaction do not need to be registered, providing they fulfil the conditions, but those taking ownership of the oil before selling it on must be registered.
Q. If I have surplus soil or hardcore can I haul it to a neighbour for his own use?
A. No. However, if you are moving the soil or hardcore from one part of your farm to another, that is allowed as an agricultural activity, your neighbour may collect the soil or hardcore from you to transport back to his farm for agricultural purposes using red diesel.
Q. What licensing requirements are there for carrying sewage sludge for the water board?
A. The carriage of human waste is not an agricultural activity, so white diesel is required. An Operator's Licence is also needed, the trailer should be tested and the vehicle excise licence should be for the haulage rate. The driver should also have the correct class of driver's licence - normally C+E.
Q. What is the situation on hauling rubble with a tractor and trailer?
A. If a farmer is collecting rubble or waste material to carry out agricultural work on his own farm and has not been involved in producing the waste this is permitted. The removal of waste material from a building site that is not the result of an agricultural activity would count as waste disposal and white must be used.
Q. Can I collect feed and fertiliser from my local merchant using a tractor running on red?
A. Yes, if it is feed and fertiliser to be used as part of an agricultural operation on your own farm moved by your tractor.
Q. Can I haul hay and straw to horse owners using red?
A. A farmer transporting his own produce with his tractor may use red. A contractor who is employed to harvest and then move produce may use red, but a contractor employed merely to move someone else's produce must use white.
The end use of the hay and straw is irrelevant. An Operator's Licence would be required when delivering produce more than 15 miles from the farm.
Q. Does hedge cutting for agricultural, equine, domestic and local authority customers qualify for red diesel use?
A. You can use red diesel for cutting hedges and verges that border public roads. To merely cart away the cuttings as a result of someone else doing the hedge trimming would be classed as haulage, for which white diesel must be used.
Hedge cutting qualifies as horticultural activity and using your tractor for purposes relating to horticulture fuelled on red diesel is allowed. However, preparation and maintenance of recreational and sports facilities is not classed as horticulture and therefore red diesel is not allowed for these types of activity.
Q. Is there a limit on the distance I can travel with my own grain to a mill? Does the same rule apply when delivering your own straw to other farms or stables and your own-bagged potatoes to shops?
A. In terms of red diesel use there is no mileage limit for agricultural tractors if they are being used for bona fide agricultural, horticultural or forestry activity. But an operator's license would be required when delivering produce more than 15 miles from the farm.
The movement of produce to market or for processing using red diesel is allowed where the produce is incidental to an agricultural, horticultural or forestry operation performed on the land.
Q. Can a contractor removing slurry/sludge from a cheese company take it to spread on nearby farms using red diesel?
A. No. This is classed as waste disposal/haulage, since the cheese company is paying the contractor for the waste to be removed from their premises - either in cash or in kind.
If the sole purpose of the operation is to enrich the land rather than to dispose of the waste it would be a permitted use. As a rule of thumb, a good guide is that a fertiliser is an input paid for by the farmer to put on his land for agricultural benefit. Where the waste ends up is irrelevant.
Q. Can I deliver and collect livestock from market using a tractor running on red?
A. If you are delivering your own livestock you can run on red, although an Operator's Licence is required when delivering produce more than 15 miles from the farm. When collecting your own livestock there is no mileage limit. If hauling for somebody else this would be classed as haulage and white must be used.
Q. Can I deliver farmyard manure to private houses and gardens with a tractor running on red?
A. No this is not allowed, it is classed as haulage, unless you are delivering the manure for processing, to market or to a place of associated temporary storage or to a waste tip. The movement of the produce must be incidental to the agricultural operation being performed on the land.
Q. I have arranged to go to the local quarry to pick up some stone to use on my farm. This will be for a building which I have planning consent for. The quarry is about 5 miles away.
Can this journey be made using a tractor and trailer running on red diesel? If I were to have to put in white diesel to make the journey, can I drain out the red that is already in the tractor?
A. If you are using the stone to repair a building that is used solely for agriculture or horticulture and will be carrying out the work yourself, this is permissible. Otherwise no. If using white diesel all the red must be drained off, the system flushed through with white diesel and the filters replaced to remove all traces of red contamination.
Q. What are the rules for towing combine headers and other machinery around between a farm's own fields or other farmers' fields?
A. A farmer or contractor can use his own tractor to tow equipment used in agriculture, forestry or horticulture provided the tractor is actually used on the land as part of the work being done.
A tractor can also tow a combine header between fields where the combine is working, providing the tractor is used in the harvesting process at some point.
Q. Can I take an agricultural sprayer, which is primarily used on the farm, to spray a sports field 40 miles away from the farm, running on red diesel? Can a second tractor take a bowser to fill the sprayer also on red?
A. Maintenance and preparation of sporting and recreational facilities is not classed as horticulture for the purposes of red diesel use, the sprayer would have to be towed or low loaded to the field by a vehicle fuelled on white diesel. The bowser would also need to be fuelled on white.
Q. How far could I travel with a digger or telehandler on the road using red diesel and what rules apply for construction use?
A. A telehandler is only permitted to use red if classified at the DVLA as a "works truck" and it meets the criteria of a ‘works truck’.
A digging machine has no mileage restrictions on it and qualifies for red diesel use in its own right, though there are restrictions on what it may carry. Where a digging machine is reliant on another vehicle to transport it to and from the place where it is to be used the digging equipment may use red but the carrier or towing vehicle must be fuelled on white diesel.
An agricultural tractor misused for construction or other non-qualifying work invalidates any entitlement to use red diesel.
Q. We are considering buying an HGV tractor unit and bulk trailer to haul grain from the combine to the dryer. It may also be used for other haulage, but only our own goods and from land occupied by us.
Can this vehicle be taxed as a works truck or similar and can it burn red diesel?
A. No. The "works trucks" category refers to a specifically designed vehicle and is taxed accordingly. These vehicles are only permitted to travel on public roads for a distance up to 1km of the premises where they are based.
A typical example would be a forklift truck or a dumper truck; an articulated heavy goods vehicle cannot be reclassified as a works truck.
Q: Can I run on red diesel when using a high-speed tractor (which is predominantly used as a conventional tractor) to haul my own produce on a motorway?
A. To qualify for red diesel use the tractor has to be an agricultural tractor designed and constructed primarily for use off road and used solely for purposes relating to agriculture, horticulture or forestry.
So, if this tractor fits this about description and is only using the road in connection with an agricultural, horticultural or forestry operation then use of red diesel is allowed as far as HMRC is concerned. There is no set distance limit on how far a tractor can travel so long as it fulfills the criteria above.
However, an agricultural tractor is defined as one which cannot exceed 25mph. As this high-speed tractor will travels at speeds greater than 25mph it may not fit the classification of an agricultural tractor. You would need to take this further with DVLA to ensure the tractor is correctly registered.
Q. Can I use red diesel for gritting public roads and are the rules any different if gritting on private land?
A. If the gritting work does not involve gritting roads at all e.g. only private land, then use of the public road to and from is not permitted unless fuelled with duty-paid fuel, as there is no qualifying activity.
But, if they are gritting private areas as well as gritting the roads adjacent to them, the use of red diesel is permitted, including the journey to and from.
This is the sort of thing that causes more confusion that it resolves. Or to put it another way parts are just plain wrong.No grey areas ,just wrong.
Consider the question regarding Agricultural tractors ,red diesel and speed limits. What a mistake! The definition Agricultural machine ,belongs to the construction and use regulations. These regulations govern amongst other things ,speed limits . The Hydrocarbons(road fuel)duty regulations do not draw vehicle definitions from this source.They are drawn from the Vehicles excise act. This in turn takes its definitions from the Driver and vehicle licensing regulations.
The problem is that because the two sets of regulations sound like they are refering to the same thing the unwary often try to hybridise them .Operator licensing for example takes its derivations from the construction and use regulations. Hence an Agricultural machine may become subject to operator licensing . For matters concerning taxation class and type of fuel ,it is irrelevant because these draw definitions from a different source.
Edited by Mobile Milling Mike
Etc, etc............................
I reckon there's piles of stuff in there that the legal profession could pull to shreds, or at very least obfuscate sufficiently to help someone avoid prosecution.
They never seem to twig on that clearer simpler rules would not only help people know what's permissible and what isn't, but would also make prosecution so much easier when people decide to blatantly ride rough-shod over the regulations that most of us try to abide by.
I do agree.The problem is however that in 1989 the regulations were indeed simplified . The problem was however that too many people continued to try to make the rules work as they had done before. As one police officer explained to me ,out of court, where he had been giving the factual evidence regarding an agricultural machine. He complained that no one had informed them the rules had changed and the thing he found hardest to understand was that the new rules actually assisted the vehicle owner. Not somthing he was used to.:confused1:
I have watched with dismay over the ensuing 25 years as more and more poor interpretations and nonsense have almost buried the true nature of the various regulations.
I do regret that my own case was in what is known as a court of "no record".This means that it didnt become a stated case. In hind sight ,this was unfortunate for all concerned . We certainly covered the situation in depth. What was supposed to take about an hour ,wound up taking 8 hours of legal argument ,and we ran on till after 7 oclock in the evening.
The Corby castle case has certainly been a refreshing improvement.
But didn't you say appeal court and Judge
Wrong on most counts ,and I would know. I took the whole issue to the appeal court twice, first time the judge threw out the prossecution barrister and told him to "go home and study law" seccond time I won ,but against an A list barrister!
Quote Bob that's a brilliant Q and A, would I be right in thinking if the word Agriculture was replaced by the word Forestery! it would still be the same?
As far as I know Steve Agri,forestry and fisheries are banded the same.
Many of these cases end up in the high courts to seek ratification , complex planning, traffic and tax cases often confuse magistrates. It does not always need to be a criminal case, some cases like these can end up before the beak just for clarification.
Bob
Edited by aspenarb
Hmmm, I am quite interested to know the details of the alleged crime.
It started with a routine stop by the police ,of an agriculturally registered vehicle,derived from a 16 tonne hgv lorry. several alleged offences were reported and it all went to the magistrates court. I had left a solicitor to deal with it as I considered it pretty straightforward. They all made a complete pigs ear of it so I appealed. The first time it went to appeal ,the CPS again made a pigs ear of it. The appeal court judge stopped the case and admonished the cps Barrister .One of the principle reasons for this was because the regulations had recently been changed and the effect of the change was retroactive. The court were ,as is normal ,working from "stones justices manual" which of course wasnt sufficiently current to cover the changes. As I pointed out,Law becomes effective once it recieves Royal Assent,and not when stones have printed their latest edition.
The judge appologised to me but said that the appeal must be reheard before another court. At this hearing the CPS brought in one of their big guns,who at least had some understanding of how the law worked on these issues. The charges were all rather minor but involved it being necessary to prove that this was not an Agricultural vehicle but an ordinary HGV. There was no direct charge regarding red diesel but all the framework of the various regulations was explored in depth. One stated case I refered to,which is ,to my recollection one of the first involving the revised regulations was "Frees Land drainage" interesting reading you may find.
