Why? each crate comes with a tank that will make two lids. I have trouble getting rid of our spare tanks just giving them away. Or do you manage to get paid for the spares :biggrin:
I use the lids on our vented bags as well and we have dozens of bags of 6in blanks waiting to be put through the kindlet.
  • 3 months later...
  • Replies 25
Sometimes by hand or like this http://arbtalk.co.uk/forum/firewood-forum/64594-low-tech-ibc-tipper.html I do like unloading by hand as you can separate any processor waste but it depends how much time I have and how big the logs are.
How long do they last?
I have had a few where the base rotted out but they where awful when I got them. Not had a good one show any signs of deterioration but I have only had them 2 or 3 years. The feet sometimes need fixing if your a bit rough with them :001_rolleyes:
Thanks for the link. That's just what I was hoping but was told yesterday that they won't last long if I tip them.
I just need to sort some forks out for the old David Brown and we are good. I see you put chicken wire inside the cage too. I was hoping it wouldn't be needed but I suppose the logs will tip out easier with it.
Not sure on the chicken wire. I now don't use it for any of the larger log sizes ie <10". Any logs that fall out during seasoning I just post back into the crate. It is good for the smaller sizes but I would zip tie it in carefully or it tries to slide out when you tip the logs. I don't think tipping the crate onto a hay bale is going to do them much harm but I have only just started doing this so don't know for sure.
Stick a post into the floor and lower the back of the IBC onto it and it will tip forward. We used to tip metal shavings into skips with a fork lift at a foundry using this method.
