I am pleased to report that the 560xpg that came free with the crappy grease gun is brilliant, however.
That's unfair, my crappy grease gun came with a non-heated 560xp! The one I bought before came with a 346xp
Sent using Arbtalk Mobile App
They are indeed a complete wastefof planetary resources.
You have to hold you thumb, or chosen body part over the hole in the re end cap
Even then most of them still don't work!.
Why husky bother I just don't know..
•Take the end cap off.
•Then hook out the loose cup from within the tube.
•Pack tube with grease that came with saw or other suitable grease.
•Place loose cup back in tube, with flat side against grease.
•Secure end cap.
•Position tip in bar tip grease hole/s or against central grease point of clutch, (some Huskies).
•Place palm of hand over end cap and press down firmly.
•If this is the first time using the grease gun/tube - you'll need to pump it a few times to get the grease down to the tip.
•Continue firm downward pumps until grease appears at edge of bar.
•Greasing the the clutch, is a similar process. But you have to watch more carefully, for the appearance of grease as it appears in the central area of the clutch.
•You don't need to plaster the clutch in grease. So cease pumping when you see a little oozing out.
