Moisture meter accuracy.
Mark Bolam
  • Replies 61
Easier to microwave for 2mins on high. Leave it for a few minutes to cool then weigh. Keep repeating til it stops losing weight. Quicker and more energy efficient than an oven imho.
Or if you are a tight Scotsman like my me, you just leave it beside the log burner for a few nights and heat it that way. Cheaper than electric.:laugh1:
Then oven method is scientific method (ie 105 C until a constant weight is reached), but having never used it for a firewood log it may well not the most practical. To speed up the process you could use a low density species (eg spruce) and cut the log into kindling sized pieces.
thanks guys. do you have first experience of oven or microwave? I'm a little wary of using a system (oven) that takes potentially 24+ hours.
i stumbled across testing moisture content from the biomassenergycentre.
I use a moisture meter from Axminster tools and for chip it is very accurate.
I have calibrated ours at various MC using microwave and scales. It reads a little low at 45%.and above. I have used ours to monitor chip MC both home produced and bought in for many years , and it is still fine.
If you use the microwave method small pieces low power and go steady as you approach 0% otherwise you will have a fire and a wasted test.
they're just down the road from me (i'm an axminster lad) so i'll pop in there tomorrow to see what they have. thanks for the tip!
The Stihl one is pants, but the more expensive model I bought still fluctuates a lot depending on how hard/deep I insert the prongs.
I still think a very cheap calculator with '14%' on the screen works best on my elderly and vulnerable customers.
