Is that so? - I use a guide all the time - still hand sharpen from time to time... using a guide actually gives you something to aim for when it comes to hand sharpening.
Using a guide has been the main way I've improved my sharpening over the last 3 years - hand sharpening is better than it's ever been....
My sharpening hasn't improved at all lately. I learned to sharpen properly a couple of decades ago.
I still maintain that people should learn to sharpen without an aid before they learn to sharpen with one.
I once had a student that came on a placement and couldn't sharpen without a guide, he had to ask how I could possibly sharpen saws without one:thumbdown:
  • Replies 24
5.5, 5.2:confused::confused:
What happened to 5/32, 3/16 and 7/32? Only sizes I've ever needed in nearly 30 years.
5.2mm files are 13/64 - and it actually matters if they are 7/32 or 13/64 on 3/8" Chain.
The front edge of the Stihl cutters in 3/8" is lower than on Oregon, that's why they specify a smaller file.
Changing to a smaller file when the cutters are filed back makes sense for the same reason.
Can you put a 5.5mm file in the holder in place of the 5.2mm ? It seems the obvious choice instead of buying all the lot again. If you know the angles you can do it just with a file so it can't be that critical.
Likely not a good idea - the hight of the file will be off, compared to the top plate of the cutters,
Anyway, it is best to file freehand, looking closely on what you are doing! :wink:
