I can understand points 2, 3, 4 and 5 but not 1!
Can someone please explain how a climber hanging from a single point can generate a force greater than his weight? (Assuming the climber is static)
I could be missing something but need help.
Basic up and down movement while climbing.
Thanks Kevin.
So the force, at particular points in time, can be up to 50% greater than the climber's weight.
Honestly I believe that it depends on how sloppy a climber you are. In this non scientific preliminary study, they used one climber going up and down the rope in a standard normal way. The drop tests were done in a tower.
Yes, I accept what you're saying.
My mistake, in reading, was to presume it meant that the climber exerted this constant force on the anchor point.
Thanks.
