Glad to see its a proper 075 and not a converted 051 as it has the hand operated oil pump aswell as the automatic oiler.
Check the chain to make sure its 404, it prob is but looks small in the pics.
Remember also these saws will only rev to about 9500 as peak torque is made around 6500rpm. They sound like they aren't revving out like newer saws, its not a fault they are meant to be like that.
Nice saw, newer than my 051, but still prior to the brake-mounting crankcase, if you remove the starter/fuel tank assy, the date of manufacture is inside, also it'll let you know which type of starter it is as the ring type is NLA
Sent using Arbtalk Mobile App
