insulation celotex ga4090
carpenter1
i need to find 18 sheets insulation celotex ga4090 1200 x 2400 boards?
i have been quoted £32 is this a good price?
can i get seconds cheaper as they do the same job :confused1: but will the building inspector approve it:confused1:
I used sheets from Seconds and Co and the BCO had no complaints. If you have doubts give your BCO a call. I have always found them very helpful. The usual defect with the seconds is uneven thickness so only use them if this does not matter.
what thickness is that, ive got a load of spare 50mm
