advice for a noobie chainsaw user
chrismechanic
yes, i would say it's a bit of ring or spark plug has made those marks.
the damage could be removed on the mill using the rotary table to spin the head around, just on that flat face inside the combustion chamber.
that would lower the compression ratio too by a small amount, but tbh you dont want to lower it by much or you'll end up with a poorly running bike :thumbdown:.
so when you say angle are we talking the dished part that leads up to the spark plug hole, apart from that part of the head the rest looks flat from the pic.
you could have a shim made to fit inbetween the cylinder and the head, that would also work and if it lowered the compression too much could easily be removed.
here is a very small 2 stroke head i did some external work on... the guy just wanted the outside cleaning up after crash damage :thumbup:
before..
and after
chris
  • Replies 166
before..
[ATTACH]139923[/ATTACH]
and after
[ATTACH]139924[/ATTACH]
chris
This thread should be re titled the engineering / tool room thread ! Rotary table takes me back ! Last time I did anything like that it was ( Label 1 Circle centers X 0.00 Y 0.00 circular polar radius what ever, z minus abit M03 incremental , circular polar 360 degrees ) call label 1 REP 2 . M25 Stop .....
