Put the thermostat in hot water and make sure it opens ok. If it doesnt its faulty obviously. If you get stuck and need the machine, run it without the stat fitted.
Sent using Arbtalk Mobile App
I have kwick chip 160, ImageUploadedByArbtalk1382817245.857156.jpg.9cda501451b5ee487f51c77051c0e304.jpg
Bloody good tool,
As far as I know they suffer from three problems,
1 overheating
2 electrical problems
3 axel weakness
Mines had the problems solved by the following,
1 overheating, solved by cleaning rad/ water pump and flushing rad/engine through , fitting a new exhaust ( the old one was blowing causing hot air to stay in under the hood)
The exhaust was fitted, and wrapped in heat Sheild wrap to keep the heat in the exhaust,
2 electrical problems, I've had the no stress bypassed on mine so it's just controlled by the bar,
3 axel problems,
Luckily mines has a new 2" box axel before I picked it up but nice just fitted new indi spension units, and new wheels/ tyres,
Hope this helps mate
Hi mate it was one from a local tyre depo took it out the scrap bin for free,
I believe it's a Peugeot exhaust mate,
Do you need a few pics?
