old gate
carpenter1
It's a bit odd.
The scroll ends look hand forged, but the joints look arc welded. This is slightly strange as cold bending the scrolls is quick and easy (and cheap) whereas hand forging is not. However then to blob on a bit of weld and not even bother to grind it off neatly is somewhat surprising. My best guess would be that it is 1960s/70s - much earlier and arc welding gear would not be common. Much later and I would expect to see really dull cold bent work. It may be welded because it's mild steel and old smiths who were used to fire welding wrought iron just couldn't get to grips with the difference in welding practice for mild steel.
Alec
edit: could you take a close-up of the blob bits - about halfway down, joining the curves to the uprights.
