Get yourself a cheap stihl combi tool.
hazzygawa
I have a hl 95k hedge trimmer.
If you loosen the handle off and loosen the engine from the shaft, pull the shaft from out from both and slip in a combi tool shaft.
Hey presto. Combi tool.
Only found this out as my mates ct packed up and we swapped my engine over.
I wonder how much just the ct pole is?
Or you can do that.I do this. Good with chainsaw head
But if you need the extension pole this is a good option
I just bought the telescopic shaft section from a pole saw for £230, all bases covered with only one engine! :thumbup: Which can be sold after warranty finishes and replaced at minimal cost/loss.
Won't suit everyone but for the extremely varied yet not always regular work I use mine for it's ideal.
