Hi guys as the title says I wanted to ask if it's possible to swap the standard metal rings on the first gen butterfly connecting the leg loops and bridge to the new gen shackles and bridge and put a swivel on.
Thanks
Gareth
just wack a swivel on the existing..
Can't do it my bridge is fixed. At the moment I've got a D shape nut tighted shackle on it which I fit a 3 way to that
This us a pic of the same one as mine look close at the red bridge and the rings it's connected to.
Never realised it was first generation one you were asking about, I missed that bit!
So how old is it? As above it must be at the end, or over its service life.
Have you looked into fitting mallions?
Get a short length of 13 mm rope, tie a stopper knot in one end, feed through first ring, slide swivel on, feed through second ring, stopper knot on job done no need to cut anything off.
I'd post a pic but my butterfly is out on loan.
Sent using Arbtalk Mobile App
