ive always used a double hand ascender to ascend as i feel its more ergonomic than a single one. the only problem is they have a second superfluous cam, which increases the weight(im aware the design was originally for foot locking). has anyone thought(or is there already) to design a single cam double handed ascender. i was considering grinding off one of the cams but might weaken the whole structure
Are you actually serious about shaving the weight of the unemployed cam off your ascender? :confused1:
A short haircut and empty the change out of your pockets! :biggrin:
Thanks mr squirrel. He was probably referring to the earlier kong double ascenders that popped out due to lack of safety features. I still use the same ones just not for life support. I noticed the ascenders are riveted together. Could be taken apart one section removed then reriveted. Is that straight forward enough?
