where does one measure the bar from to determine it's length.
many thanks woodman1
Generally from where the dogs are mounted - thats the front of the oil tank and not from the clutch cover!
hello spud,i measured the bar and its 101/4" with a 50 link chain.so will the Micro Lite Pro- 130MPBK095 and 95VPX be okay,sorry to be a pest.
all the best woodman1
Yes, or more exactly, from the front of the saw body (usually front of the oil tank, but not always) to the top of a cutter at the tip of the bar.
"Called" length usually is inaccurate, and in some cases downright misleading....:001_rolleyes:
The 130MPBK095 is 13" and uses a 56 link chain 1.3mm gauge 0.325" pitch - not sure how the current bar and chain come in to the equation - just depends on the bar mount which we have already gone through:confused1:
nough said
