spiderjack clutch
jeanesy
Every two weeks?! That's a bit much. What rope were you using before you changed? How do you get on with velocity?
Was using new england tachyon. At 11.5mm it seems considerably wider than the velocity. In 18 months ive had one new sj body and countless cams... resorted to buying in bulk. Velocity at 11.3mm just falls through the device and is a pleasure to climb with. Had a month out of one cam so far...
I'm on tachyon now. Isn't velocity what the guy who does the spiderjackery videos uses? How do you find it to grip?
