Mitsubishi Shogun Warrior swb 55 plate came with 285 55 r 18 Pirelli Scorpions, seems BF Goodrich dont do a tyre this size, does anyone know what size alloy wheel is needed to find the closest available BFGoodrich AT tyres to the original Scorpions?
Cheers
TC
There's a much better selection of tyres to fit 16" rims than 18" rims.
BFG has a tyre size guide for the AT at
http://www.bfgoodrichtires.com/specs/all-terrain-t-a-ko/44.html
There is a LT265/65R18 (for a 7.5" to 9.5" rim) and a LT285/65R18 (for an 8" to 10" rim) which might fit, but you'd need to check that the increase in diameter won't cause a problem. It's likely that your rims would take either of these since they are likely to be in the 8" to 10" width range.
The 265/65 is approx +15mm in section (+30mm on diameter) and the 285/65 is approx +28mm on section (+56mm on diameter) compared to your 285/55's.
I would have thought that it is very likely indeed that the 265/65R18 BFG AT would fit without problems, provided that it is available in the UK.
It is, found this pic of the BFG ATs on the Warrior's 18 inch alloys -
