Hi all, a am looking for advice on buying the correct winch for my Iveco 4x4, can you please let me know what you have and good/bad points etc...
Also which brand I should go with and also stay clear of...
My Iveco weights 3000kg empty and 5500kg loaded with a train weight of 9000kg
The winch will be used for winching stems over, extracting timber and hopefully not recovery in the highly unlikely event that I get stuck
Pics will be great
  • Replies 20
Pics will be great
Hi chris h14 husky super winch or a red winch that's mate in some 8 ton is the winch and husky 5,5 ton thanks Jon
If I'd won the lotto mate trust me I wouldn't be buying Chippers winches and chainsaws
I do live in hope though...
HI CHRIS i like it we all need to better our self and thats what your doing mate good on you the super winch h14 is 5500kgs pull single and reds will do one that pulls 8000kgs mate thanks jon :thumbup:
I would get a pto hydraulic pump put on it chris, there's 4 points on it 1 can go I believe, then you can run hydraulics to the front for a better winch and snow plough option, then in winter run it on Cherry:biggrin:
Nice big hydraulic husky winch or whoever makes them. 6-8t should see you well!
Sent using Arbtalk Mobile App
HI ROB 6ton ok but 8ton one very large that will put the truck on it stops mate the h14 6400kgs hydraulic will do the thats what a chap runs on there same truck as chris thanks jon :thumbup:
I like the way you think Stevie mate!
