igland 8000
cosworth
wanted igland 8000 or 9000,to fit county
I found anything bigger than the 4000 just pulled the County backwards. Also bear in mind anything up to the 1184 was only safe to tug 4.5 tonnes of traction.
We did have an 8000H on a 974 but the electro hydraulics played up and were converted to hydraulic only.
For static pulls the Farmi 8 tonne was better as it acted as its own ground anchor.
Be aware also if you add front weight and it still rears up you can crush the bell housing, this is one of the reasons the highland bear had the branch deflectors in tension.
  • 3 years later...
