I have a great fix for a ms261 problem, it's called the husqvarna 550xp, available from any good dealer
Sent using Arbtalk Mobile App
dont they have loads of problems like the 261....??? remember a thread 550 playing up again?:confused1:
  • Replies 50
OK, basically when the saw is idling, the clutch should be spinning around inside the clutch drum with no contact between the clutch shoes and the clutch drum.
You usually get a little friction between the crankshaft and the drum and clutch but this is so small it wont effect the idle.
If the saw is cutting out when the chain brake is applied, the application of the chain brake is increasing the contact friction between the previously mentioned parts to the point that it is dragging down the revs at idle to the point the saw stalls.
It may be the bearing is shagged, twine around the crank shaft end and washers is a common one (probably not in your case as it has been cleaned), a busted clutch spring can do it as can just wear and tear on these parts.
The MS261 does have well documented issues in this area:thumbdown:
Yeah, all down to computers, can't trust computers, I'd be rich if computers weren't around... And have less saws
T:lol::lol::lol:
It wouldn't but it would explain why the drum not going on.
The cutting out could be many things. Like carb issue.
The impulse line do have a tendency to go on these.
Is the carb adjusted to factory, and does it make a difference if adjusted. Also what is the plug colour?
Cheers for the info and yes it does seem the ms261 is a a well documented failure
Yes the spark looks fine as do the clutch springs
Can't see the drive fear arm
Will gave a look in ze morn
But how would that explain the cutting out when the chain brake is applied
Think some of us are missing this point:001_rolleyes:
All joking aside, check the clutch bearings, and if it dings whilst idling, you've got a worn spring
Yes - sounds like clutch springs, binding betwen the clutch and drum or needle bearing!
Clutch springs seem fine
Gonna replace needle bearing but still can seem to seat clutch drum properly which is freaking me out
