Any of you guys had any experience with one of these? I'm picking a great example up of an old gent next week, he's had it from new and only used it a few times, apart from a generous coat of dust she's brand new!
Check the fuel lines, and smell the fuel in tank, if its old it will be manky. If so the carb will need a good clean out aswell.
Don't know about the saw, just a techs advise.
Luckily the old boys background is garden machinery so he looks after them, he's got a serious collection of old school stihl's but this girl is just taking up space in his garage there serviced every year without fail it even comes with a box or sundries he reckons its a 1974 model? fired first pull and running a 32" bar, not sure of power but feels meatier than my ms460
Model: VI-944
MANUFACTURED BY:
HOMELITE CORPORATION
PORT CHESTER, NEW YORK, U.S.A.
SERIES OR ASSEMBLY NUMBER:
YEAR INTRODUCED:
YEAR DISCONTINUED:
1974
ENGINE DISPLACEMENT:
5.01 cu. in. (82.1 cc)
NUMBER OF CYLINDERS:
1
CYLINDER BORE:
2.0625 in.
PISTON STROKE:
1.50 in.
CYLINDER TYPE:
Aluminum with chrome plated bore
INTAKE METHOD:
4 reed pyramid type
MANUFACTURER ADVERTISED H.P.:
not advertised
WEIGHT :
14.5 lbs. (6.5 kg) powerhead only
OPERATOR CONFIGURATION:
One Man operation
HANDLEBAR SYSTEM:
Rigid
CHAIN BRAKE:
none
CLUTCH:
Centrifugalq
DRIVE TYPE:
Direct
CONSTRUCTION:
Die cast magnesium
MAGNETO TYPE:
Wico flywheel magneto
CARBURETOR:
Tillotson HS-151A
MAJOR REPAIR KIT:
RK-23HS
MINOR REPAIR KIT:
DG-5HS
AIR FILTER SYSTEM:
Cellulose fiber element
STARTER TYPE:
Homelite automatic rewind
OIL PUMP:
Automatic gear driven with manual override
OPERATING RPM:
7,500
IGNITION TIMING:
Fixed at 30 degrees before TDC
BREAKER POINT SETTING:
0.015 in. (0.38 mm)
FLYWHEEL/COIL AIR GAP:
0.005 to 0.007 in. (0.12 to 0.17 mm)
SPARK PLUG TYPE:
Champion CJ-6
SPARK PLUG GAP:
0.025 in. (0.63 mm)
CRANKSHAFT MAIN BEARINGS:
Ball on mag end, caged needle roller on clutch end
FUEL TANK CAPACITY:
35 fl. oz. (1035 ml)
FUEL OIL RATIO:
32:1
RECOMMENDED FUEL OCTANE:
Regular grade
MIX OIL SPECIFICATION:
Homelite Chain Saw mix oil
CHAIN PITCH:
3/8 in.
CHAIN TYPE:
Oregon 72D
BAR MOUNT PATTERN:
14 link
SHORTEST GUIDE BAR SUPPLIED:
16 in. (40 cm)
LONGEST GUIDE BAR SUPPLIED:
36 in. (91 cm)
It's not going to help you put it back together again but I like the original intention of the name. Charles Ferguson founded the Home Electric Lighting Company in Conneticut in 1921 - his aim...to make lightweight generators for home use.
I have one, get a rim sprocket for it, get an 8t rim, undo the muffler, remove the spark arrestor and it'll roar and rip!
To get the age, remove the recoil plate, the date is stamped on the inside, mines a '72 ImageUploadedByArbtalk1376351930.967417.jpg.51a29470258ccb413cc74d05908ae981.jpg
You can't get new AV rubbers, air filters are like rocking horse crap, and Oregon have obsoleted some of the bars
Sent using Arbtalk Mobile App
