Alycidon, Burley do the 12kw Wakerley, the largest of their stoves. Can't wait to test it.
And that is a nominal figure . In real world terms I think it would be more than that . My 5kw Burley sure punts out more than 5kw .......
It'd take more than 100 degrees to catch oak flooring anyway. Might mark it a bit. Mine sits on about 125mm of York stone. The hearth is 125x125mm planed oak. No worries.
If there is a problem in the future and their house burns down, that's when doing it by the book counts.
I only sell mid market and top end stoves, I do have to go and have a look at their construction in their works before getting involved but I have every confidence that they are indeed a good stove.
What is unique is the air flow design, usually you have an air curtain down the inside of the glass ( secondary air) that keeps the glass clean and sometimes an additional Terciery air supply in the rear of the firebox above the fire. These Burley stoves do not have a secondary air curtain but do have 4 Terciery air supplies, upper and lower, left and right so that the fire burns in a circular motion. That much air will make it burn like hell and I do have reservations about the degree of control that is available but as long as the stove is not oversize for the room it should go well.
12kw will nicely heat a room of 144 cu m volume given poor insulation, or 168 cu m for average insulation, thats a big room in most peoples books.
A
