A new (well new to these shores anyway!) carving chain from oregon for the chainsaw carvers out there. Have been trying to get this for a while from Baileys but no joy - suddenly there were a couple of 25ft rolls here in the UK!
Not used it yet but apparently it is excellent for fine detail and finishing work. Instead of having a space between each cutter you have a continuous sequence of cutters (as in pic below).
Available to buy in custom loops here Custom chain loops
1/4" is labelled as .250 - this is because the "/" symbol interferes with coding on the site.
This is in addition to their unguarded 25A carving chain.
Oregon have also brought out a whole range of new 1/4" drive sprockets for Stihl, Husky and Echo chainsaws as it can be a right pain trying to find these from a dealer.
You can download the pdf here http://www.oregonproducts.com/pdfs/Sculptor_A107046-AC_lo-res.pdf
So for a change hats off to oregon for making something simpler and providing a larger range for the pro user. I will be uploading all the new sprockets to the website later this evening (will try anyway :blushing:).
:001_smile:
Excellent, will be ordering a sprocket for an echo as soon as possible :), well pleased
Sent using Arbtalk Mobile App
No worrys - I think oregon have done really well here by making the 1/4" sprockets easier to get hold of.
:001_smile:
I think I have most of them - just trying to get time to get pics and get them listed - but which one is it you're after i.e. what echo do you have?
Send me a PM as I sometimes only check threads every few days.
:001_smile:
Got one for the echo 2700ES Rob?
:001_smile:
  • 3 weeks later...
The .pdf file says "*WARNING: Failure to use this chain on bars with nose radii of 12mm or smaller can result in severe kickback".
No good on the standard rollmatic bar then :( I still dont like loose chains.
Read more
