Cornwall to Northamptonshire, then Northamptonshire to up here. Surprisingly cheap to get timber cut there, hence the economy of it all.
TCD
If the job comes off I might be able to back load the timber lorry with Hardwood from Northampton area. If everything goes to plan!!!
Help; the heat has made me go extra-thick! Are the two above related and if so do you mean put a load on the lorry from nhtn back to devon?
  • Replies 25
It's now't to do with the heat!:001_tt2:
I think he means he is going to Devon loaded and going back to Northampton empty! Unless he can cart your timber as a going "back load".
Get this man a Cornetto!
Yes - means the lorry is loaded in both directions.
What would you charge roadside for nice SC?
