  • Replies 23
only tongue in cheek!! I agree 100%:001_smile:
sorry mate i should of said, wohohohaha after that post with a couple of :001_tongue::001_tongue:i press it all the time just for the hell of it, it is like a magnet to me lol:001_smile:
he-he!:001_smile:
ill stop now or it could get really silly. Halfway through bottle of red. sorry. Ive never even driven a mog!!:sad::
he-he!:001_smile:
i like silly, so does frank he will be perming his mullit just now, so wont want to get too excited until it sets, then he will be on here with a vegance.
its all part of our world domination. he is my number 2, but since he is under the big hairdryer you can have a shot at the title:001_tongue:
i have some buttons that change the oil flow that alex told me never to touch:ohmy::001_smile:
Dual circuit hydraulics
One button turns ON circuit II and gives it flow priority
One button switches flow priority between circuit I & circuit II
With circuit II button OFF
flow priority button in OFF position = circuit I = 45L/min.
flow priority button in ON position = circuit I = 18L/min.
With circuit II button ON
flow priority button in OFF position = circuit I = 18L/min & circuit II = 45L/min.
flow priority button in ON position = circuit I = 45L/min & circuit II = 18L/min.
circuit II is for mounted implements with there own dedicated spool-block &/or hydraulic control units, circuit II has no pressure relief valve as it is reliant on the pressure relief valve within the implements dedicated spool-block &/or hydraulic control units.
If you have dual circuit hydraulics you should have a balance pipe between the feed & return pipe quick couplings behind the cab so overpressure of circuit II cannot happen if the circuit II button is accidentally pressed.
i have pressed the buttons loads of times, so there must be a balance pipe, it also has a screen on the dash, that tells you speed,revs and radar. is that for ploughing? it has the terramatic controls, for the back and front linkages.
