I understand more plugs for bigger stumps, but is there like a guide or something to determing this? like plug to stump ratio?Anyone care to explain please :)
Because they are exspensive you don't want to use more per stump then you have to.
A rough guide to how many to use depends on which tree stump you are treating for example you will use more on a 20cm poplar stump then a beech stump the same size.
I set them at between 3 to 4cm on smallish stumps and 6 to 8cm on bigger stumps with one in the middle for good measure.
Mite not be going by the book but it's work'd on all what have used them on so far.
Jut be careful when you order them though,it's a minimum of 100 at £60 plus drill bit
at£6 plus delivery at£10 plus VAT ends up bout£88 for 100 so best order 2 or 3 hundred if you can.
A rule of thumb is to calculate the tree diameter divided by 1,5.
For example: Diameter 11” divided by 1.5 = 7. Apply 7 plugs evenly spaced.
i took that from their website. where do you guys get hold of them?
