No a fell was out of the question, the field behind had water and waste pipes running above and just under the ground.
Thanks again for all of the constructive feed back, hopefully my next vid will be an improvement.
Nice vid, you will be swinging some real bits out before you know it. Half the battle is having a good grounds man. If you feel comfortable with the groundy you will be more confident up the tree.
Nothing worse than a sh#t groundsman.
