  Old Mill Tree Care said:
I don't do it all because I can't stand the amount of bounce in the system and having to to make the TIP a bit lower can be annoying.
Of course, there are exceptions when I would use it for safety reasons.
You've said that before and I don't understand because the reason I use base ties is precisely because it allows me higher access into the canopy. I am not sure if srt would even be worth it without the base tie. The redirects I use in this tree would not be possible without a base tie. Having a base tie also allowed my ground guy to add additional line into the system. This required another line being tied onto my 200 footer.
[ame]
[/ame]
[ame]
[/ame]
A possible misunderstanding.
I use a base tie to gain access to the tree but the tie in to the top of the tree to start work.
I only work off a base tie if I'm doing a crown lift or a dead wood job or if its a thin tree and I need to spread my weight over multiple branches, as you describe Kevin.
Don't forget though, most of the trees I climb here are around 20-30m tall and quite bendy.
I'm sure I would base tie to work if I was in really big trees.
Sent with my iPhone from me, to you!
I have no idea what HAAS stands for but its a knee ascender with a bungee. same as my rope rocket type setup :)
Got some calamine last night Ewan, splices so easily. Lovely rope to work with. Hope it climbs well too
Read more
