Hi all,
Anyone recommend a good finish for a carved brown/black bear.
Looking through wood stains etc and was seeing if anyone has used any and which colours would go well.
(For the fur, that is)
cheers
there was a thred a while back on this. get a jam jar fill with vinegar and chuck in a couple of iron nails. leave it (with the lid loose) for a few days then pain it on. the tannin in the wood reacts with the solution to darken the wood. I know splinters uses this quite a lot. worth a try but if the wood you are using has low tannin levels its not so effective. you can improve the tannin levels by painting on a few coats of tea (no milk) first. might be worth a try if you want to avoid burning. i prefer burning but remember to oil plenty afterwards cos the burnt-effect will wash off
I guess it will depend on what type of finish you go for I treat the whole bear except for the base with a fencing wood sealer which has a chestnut stain i spray the bear with a black outdoor paint except for the snout and I then use a good few coats of Danish oil on the claws and base. ImageUploadedByArbtalk1370863241.201937.jpg.01a9f0a89bc9a1bde3bfc025545ee3c6.jpg
I reckon paint or dye/stain is the best guarantee for a full colour change.
I've been experimenting with burning lately and unless you burn the **** out of the wood it only burns the prominent surface areas leaving the hollows and recesses un-burned.
The vinegar solution works well too, I've used it in the past with 000 wirewool on oak which is full of tannins and it came out jet black.
Thanks for all the advice guys, iv gone with a stain finish and will further protect it after..having panic guessed the colour I think it went well and looks good..pics to follow later :-)
